Hi All,
I am working on an impact simulation using ABAQUS/Explicit. I'm having trouble with estimating the contact force of the two objects. The impactor is 3D discrete rigid body, I defined the total mass to it and its initial velocity using the predefined field in the load section. I have used general contact algorithm and surface to surface contact for the interaction definition. Also, I requested the contact force from the history field output using the CFN output option. The estimated contact force I get always over estimated when I compare it to the experimental result. I know that the two major factor that affect the contact force is the mass and the drop height (which is being taking care of by defining the velocity).
I am just wondering if there are other factors causing this issue?
Please share with me your feedback. Thank you in advanced.
