Hi All,
I am working on an impact simulation using ABAQUS/Explicit. The impactor is 3D discrete rigid body, I defined the total mass to it and its initial velocity using the predefined field in the load section. I have used tie contraint for cohesive element and composite layer, surface to surface contact for the interaction definition. Also I requested RF3 for reference point in impactor from history ouput. But when i plot, this force is zero.
Can somebody help me
Thank you
Thank you
