impact load
casasf
47
I am working on a foundation design for an evaporator. The compressor VERTICAL loading at the supports are +/- 74 kips. The duration of the load is 10 ms. What is the recommended load combination we can use? any references?
Appreciate your response.
Is this a true "impact" load where there is some sort of collision or dynamic action that produces impact? Is this load being produced as a result of wind/seismic lateral loads that are resisted by a vertical force couple from support legs? More information (and a sketch would be great) is needed here to help answer your question.
