Dear All,
We are discussing the requirement of impact testing on SA268-TP410 u bend tubes OD 3/4'' x 0.083''thk with our mill.
After bending we need to perform heat treatment on bending area. (temp around 650 deg C as per mill)
As per ASME VIII -1, UHA51 C (4) martensitic stainless steel needs to perform impact testing if temp is between 425-730 deg C.
Now mill is saying that they do not need to perform impact testing as it is for thermally treated
means thermally affected area due to weld assembly work.
So do we need to perform impact testing ? ( MDMT of exchanger is 10 deg C)
