bacon4life
For a 2 MVA synchronous hydro generator, what are the impacts of running without excitation for 15 minutes with the wicket gates closed? How much reactive power would you expect to see flowing into the generator. How much real power losses might occur? Would you expect an in service failure for this size unit from overheating of rotor retaining rings, rotor wedges, rotor iron and rotor winding?
I found typical advice for tripping on loss of excitation with only a 0.2 second delay, so I am a bit confused as to whether it would take many minutes for damage to occur. A previous thread mentioned a steam turbine saw about 0.65 PU for 45 minutes, but also mentioned hydro units would be different than steam units.
The wicket gates have a mechanical failsafe closing system. Although the generator is above the tailrace level, I am unclear whether closing the wicket gates would typically also dewater the unit.
