impeller
chemeng1357
Chemical
Oct 12, 2006
20
Hi
How diameter of impeller affect input power for agitation purpos?
is there relation for it?
thanks for your reply
thanks EmmauelTop
for reply,
can you address practical formulas for mixing application?
thanks
chemeng1357
The basic relationship between Power (P), speed (N), diameter (D) and fluid density ([ρ])is:
P [∝] N^3.D^5.[ρ]
Specific calculations need input from the suppliers with regards to the performance of the particular impeller type selected.
NB
The power dissipation of a mixing impeller is given by the following correlation:
P = N*p*N3D5/1000
where: P = power dissipation, kW
N = power number, dimensionless
p = fluid density at conditions, kg/m3
N = impeller rotational speed, revis
D = impeller diameter, m
Prutiew
