I have a simulation where I want to import a deformed field and run with different conditions. This is similar to what we do for Initial Imperfection studies with Eigenvalue bucklings: I run a simulation and take the deformed eigenmodes and use in the next simulation via *Imperfections.
The same setup works by running a Standard simulation, saving the Node File and import to new simulation via the *Imperfection option.
However, this does not work in Explicit simulation. So my question is, is there another way to do this for Explicit simulations?
Many thanks for any replies
