UGMENTALCASE
Aerospace
After a little help. I don't program and wouldn't know where to start but here goes.
Our NX drawings are done a specific way. One drawing file and multiple sheets. First sheet has a title block imported in has a BOM and notes etc. The following however many sheets have a different title block, same on each sheet though.
The two title block files are named differently. Stored in the same folder.
What I like to do is set up the drawing with X amount of sheets and import all the borders. With anything more than 10 sheets it's quite timely doing this.
I'm looking for a journal or something which will do this for me. So run the journal, select amount of sheets and then it imports the borders, one for the front sheet same for the rest.
Any help, journals I can play with and test or anything would be great.
Thanks in advance
Thanks in advance
