Terrencio
- Jun 30, 2020
- 3
Howdy,
Those of you who have worked with Creo/ProE know that the software splits hole cylinders into two half-cylinders - which I despise. I often need to bring native Creo/ProE parts into NX. In Creo, I usually export the model as either a STEP or Parasolid model, then import into NX. When I import a STEP model into NX, the import menu has the 'Optimize' option that can be checked; this resolves holes that in ProE are two half-cylinders into a single hole cylinder. I prefer importing Parasolid, since that's Siemens's format, BUT I cannot find a way to easily modify the ProE half-cylinders into a single cylinder - NX doesn't have an 'Optimize' option on import like it does for a STEP model.
I know that I can go hole-by-hole and use Synchronous Modeling 'Delete Face' or 'Optimize' to fix this. Is there an easier, 'global' way to do it for all of the holes in a part, so that I don't have to manually click dozens of holes in a model?
Thanks in advance for any help provided!
