bekks
Materials
- Mar 9, 2013
- 30
I have a client who had their 17-4 PH component (part of a drive roll) improperly heat treated. It was meant to be H1075, but ended up getting 1150F for 2 hours and then furnace cooled. I suggested they take a bar, heat treat it in the same manner as the improper heat treatment and tensile test it. The result was almost identical to a previous test we had done in the H1075 condition. Their main criteria is hardness for wear resistance and I will be checking the hardness tomorrow, but I was quite surprised that the strength was as high as it was (165ksi yield, 167ksi UTS, 16% el). Anyone know how significant the effect is from furnace cooling compared to air cooling? Anyone else surprised at these results?
P.S. in anticipation of background questions, this all started from a WPS development, but I don't have any concern for the 309 weld metal or the SA 516 material it is joined to.
