In a cross bonded system, if the sheath of each minor sections are physically connected and earthed at the ends of a major section, why is there a increasing voltage gradient between the earthed point to the point where the sheath are bonded? A logical guess is because of the resistive nature of the cable sheath resulting in a voltage rise as it is further away from ground. Is this the main reason?
