Edgewise
- May 30, 2003
- 11
Hi everyone,
I'm working a fairly large database of parts in excel. Typically most of the data in the spreadsheet is metric dimensions (mm). However, occasionally I'll come across a imperial drawing which needs to be added. I'm looking for something that can convert between mm and inches quickly (manual conversion is too slow).
Basically something that when I enter a value followed by the ' " ' (inch symbol) excel will replace my entry with the mm equiv. Or something that is similar.
Something else that could work is simply button that will convert the entire spreadsheet to either imperial or metric (as long as entries can still be added to either system).
edgewise
edgewise
