*Include, Input error
StanD_1
4
I am trying to include some loads when running an analysis through an input file. However I get the error when running the job: Abaqus Error: Command line option "input" value must not contain whitespace characters.
This is how i have included the load:
*INCLUDE, INPUT=ABQ2CFD\H21_7m_T15_8s\MappedPressure_kPa_at_time_784.8199999995762_s.inp
The file name is the location from my work directory folder.
i dont seem to have any whitespace characters, so I cant understand whats wrong.
If the file to be included is in the same directory from which the job is submitted then you don't need the path, just the name and extension. Otherwise, you can specify either the full path (including the disk) or the relative path (with respect to the directory from which the job is submitted).
