No. it is not normal practice at all.
Generally, when weld overlay is applied, the base metal will be CS/LTCS/low alloy steel (<--the case of low alloy is kind of specific.)
Unless the minimum design temperature is below -46 C or maximum design temperature is more than 454C, the base metal will fall under the group of the three materials.
Lee SiHyoung,
WorleyParsons Oman Engineering,
