Individual Performance of Pumps in Parallel 1
waterboy258
PH
Hi. How do i check performance, efficiency and mechanical condition of individual pumps running in parallel. I have the following information:
1. Total Flow
2. Total Discharge Pressure
3. Total Suction Pressure
4. Individual Discharge Pressure
5. Individual Suction Pressure
6. Total Power Consumption
Thank you.
With both units running together, you can't.
I'm assuming your interested in what happens when you turn one of the parallel pumps off?
2 more bits of info required: individual pump flow and liquid density.
Does 4 and 5 actually vary from 2 & 3?
