Is measuring induced EMF in a 12 VDC PM motor a good way to measure motor performance? I have sketchy info for now, but we have a customer using a 12 VDC PM motor with voltage dropped down from a 24 VDC system. Brush life has dropped from 1000 hours to less than 100. Improvements were made to the brush holder card by increasing the brush clearance and the coiled spring pressure. The brush shunt was changed from a side to rear mount to prevent the shunt catching on the BHO slot.
What is a simple way to measure back (induced) EMF?
