Hi ,
Few basic questions from a non electrical guy like me.
I am trying to select motors for dryers in Pharma industry. ( viscous paste like / powder mixing applications )
Now the no load current drawn by most motors is around 50 percent of full load current. Does it mean 50% of motor torque is consumed just to keep only the motor running? Does it depend on the load or is it independent of load on motor?
And does using a VFD influence this value ?
For eg: If an application uses a 5hp 1440 rpm motor, ( full load motor torque = 24Nm ) then if the torque needed to run only the motor is 50% = 12 Nm, then is only 12 Nm available to run the actual machine? Conversely, if 24 Nm is needed on the driving shaft , then should a 10 hp motor full load torque= (49 Nm) or bigger size be selected after considering this 50 percent torque loss?
I am assuming the values given in standard motor catalogs is inclusive of all losses. Or is it otherwise ?
Any help is appreciated.
