Influence of tool material conductivity on calculation time
Vxxxxx
MY
Hi everyone, two cutting simulations here. Everything's same except tool material. Both dynamic, temp-disp, explicit.
Simulation 1, I used tool material A, which has the conductivity of 120.
Sinulation 2, I used tool material B, which has the conductivity of 1000, 9 times larger than material A.
When I run simulation 2, it takes longer time and the error "the analysis may need more than 2000000..." always appears.
I take it as if the conductivity is higher, it involves more elements to transfer heat and therefore higher calculation time.
Maybe I am wrong. Is there any other explanation and any solution to this matter?
Thank you very much.[tt][/tt]
Thermal conductivity of material influences stable time increment:
Δt=(L^2)/(2α)
where: L - smallest element dimension, α=k/(ρc) - thermal diffusivity, k - thermal conductivity, ρ - density, c - specific heat
Thank you @FEA way.
So basically I have no other options right...
You can change other factors that influence stable time increment (mass scaling, mesh density decrease).
Noted. Thank you @FEA way.
