Inheriting part Attributes into Drafting file attributes for notes
3dr
Automotive
Jul 10, 2004
451
I'm doing this successfully now for populating Title Blocks and notes.
Example attribute format in the drafting file "DB_DWG_TEMPLATE_CL_CHECKED_BY"
Question is, if you can inherit to notes, why can't you inherit directly in the attribute value??
If you can do this, the information can be processed thru the expression system or pushed out into spreadsheet content.
We should be able to do this.... what am I missing?
Dave
Automotive Tooling / Aircraft Tooling / Ground Support Structures
NX11, Win 10 Pro
