I am in the middle of a debate regarding short circuiting on water storage reservoirs.
Do high inlet and outlet velocities encourage short circuiting or reduce short circuiting? Do high velocities increase or reduce stagnant areas in the tank?
To give you an idea of the magnitude of the tanks these have a theoretical HDT of about 3 days at average flow.
My theory is that if inlet and outlets are close together then a high inlet velocity is good but maybe a low outlet velocity is required. This will tend to force water away from the inlet position and perhaps mix the rest of the tank contents.
But if inlet and outlet are well apart both should be low velocity to discourage short circuiting straight across the tank.
Does any one have an opinion?
Ashtree
"Any water can be made potable if you filter it through enough money"
Ashtree
