Engineer1916
ET Family,
Does anybody have any experience energizing a power transformer by a temp generator with the breaker closed? Will there be a reduction in the inrush current because the generators voltage will rise from zero to nominal voltage and the transformer will not be supplied with the line voltage instantly rather it will see a voltage buildup from zero to nominal by the generator?
