Hello gentalmen,
When I insert the CatPart in a large assembly, it always went to the absolute 0 position, but I would like it in the screen center. Is it possible to do by a scrip?
Did you try to insert "Existing Component With Positioning" ?
A script can insert a new CATPart at a point defined by user mouse click on geometry. Check the portable script center, you find some code you can reuse...
Show your progress we'll help.
Eric N. indocti discant et ament meminisse periti
