Insert Here? 2
hydromech
626
Is there a way of specifying the required position of the Insert Here arrow?
In a large file I find it's a pain to drag the arrow up and down.
I want to be able to specify the features that I want to place it between.
Anyone Know?
Hydromech
Hi Hydromech
You can use feature reorder. You have to know the feature #'s first. You can turn the feature number on by using the model tree menu options picking column display, info and feature ID or #.
Tofflemire
There isn't a way except as you stated. Definately a feature they should add. I know another popular CAD package has that "Insert Here" feature.
It would also be nice to be able to drag and drop from one assembly to another... or from the top level to a subassembly... all in the feature tree.
David
hi hydromech,
Use
Edit-->Feature Operations
<menu manager>
Insert Mode-->Activate
Then pick the feature to insert after.
(wf+)
[cheers]
after what jkg is saying, if you don't want to pick it on screen then ctrl-f for search tool
I used "restructure" to move some components from one assembly to another... Not as neat as drag and drop, but works the same.
I also find it's easier to insert a component in the end of the feature tree, then drag it up where I want it.
David
The reason I asked the question is that we design castings with Pro E. Starting with the casting features and then finishing with machined features.
Retrospective modifications to the casting have to be put before the machining features.
Dragging the "insert here" marker up 150-200 features took ages.
The tip from jkg was a big help...here, have a star.
One thing that you may find useful is a tip I read somewhere on the internet (can't remember which website).
Create a point in the model tree before each major process stage, and it will make things easier for you to find.
Quoted from JKG
Use
<menu manager>
(wf+)
Close! Actually, it's under Edit/Component Manager in WF2.0.
David
Right you are.
The former refers to Part Mode.
The latter refers to Assembly Mode (under Edit-->Component Operations)
