Insert mode 1
gwenn
27
I'm in insert mode but somehow i can't seem to move it up the model tree to where i want it to be. I have a total of 237 features and i can only move it up to 232 and nothing before that. I have restarted wildfire and opened other files but it seems that only this file has this problem. Does anyone knows what is the problem and how to fix it?
Thanks!
Gwenn
You are working with a part file that has read-only features. Use 'Edit-->Feature Operations-->Read Only' (Just 'Edit-->Read Only' in Wildfire 2) and then click "Clean" to clear the Read-Only setting on the features.
[smile]
Mark
Mark,
Thanks for helping! but it's still not working. I've done what you suggested but it says "no read-only features found" Can it be any other reason? I find it really weird to just be able to move the insert arrow to the last few features and nothing before those.
Anyway, thanks again, at least now i know there's this read only option! ;-)
Gwenn,
Maybe you have some supressed features at the begining. Show them in your model tree.
-Hora
Try exiting out of insert mode and then try entering insert mode with out dragging the arrow if this is still possible.
Michael
[wavey3] Hi, I'm looking for a Job.
[ponder] Do you know of any at your company?
Thanks all. It still doesn't work. No supressed feature, everything should be active. Can i still get out of insert mode in Wildfire? i guess i'll get a new copy from the customer.
Can you make a datum plane and drag it up the model tree? Sometimes anything you do will unlock and start functionality again.
gwenn,
You could use Pro/PROGRAM functionality to suppress many components based on the status of a parameter. You could use this method if you know exactly what feature number you want to go to all the time. It might look like a Rube Goldberg solution to insert mode, but I know it would work.
Best regards,
Matthew Ian Loew
cehall, adding the datum plan didn't work.
mloew, i wish i have Pro/Program.
But i did made the insert mode work. i supressed the last few features, and came to this msg of "This view has been frozen because of illegal view instructions." and after suppressing this feature that gave me the msg, it worked! i could drag the insert arrow to anywhere i want.
Thanks for all your input! ;-)
gwenn,
Pro/PROGRAM should be part f a foundation installation, I thought. I can't beleive one would need a special module for this functionality.
Best regards,
Matthew Ian Loew
mloew,
Can you tell me more about Pro/Program?
Thanks!
Gwen
Gwen,
Please see the FAQ Pro/Program Design Resources (faq554-895).
Best regards,
Matthew Ian Loew
