InserVariable is not recognised
catia_user
Computer
Hi all
In this code i get error that InserVariable is not recognised, has anyone used "InserVariable" and did the code work ? in Catiascript ?
For i = 1 To annotationSet.Annotations.Count
Set note = annotationSet.Annotations.Item(i)
noteName = note.Name
If InStr(noteName, "notes1") > 0 Then
MsgBox "note " & noteName
note.InsertVariable 26, 0, "test\test\notes1" ' Link note to parameter "parameter1"
Endif
The documentation for InsertVariable:
Sub InsertVariable(longiFirst,
longinbCharacter,
CATBaseDispatchibase)
Sets a Parameter in a string of the drawing text.Parameters:iFirstThe first character from which the parameter is insertedinbCharacterThe number of characters the parameter will replaceiParameterThe parameter to be insertedExample:This example sets a parameter right at the end of MyText drawing text. Dim DrwDocument As DrawingDocument
Set DrwDocument = CATIA.ActiveDocument
Dim iParameter As Parameter
Set iParameter = DrwDocument.Parameters.Item("Drawing\Sheet.1\ViewMakeUp.1\Scale")
MyText.InsertVariable 0, 0, iParameter
It appears to me one needs to declare the last part as a "param" . I don't know what the last part
means; there is an unmatched "'" (single quote) in the middle of it and two strings that don't get concatenated.
' This is all way above my pay grade, but an unmatched single quote usually introduces
' some comment text, even if it occurs after some earlier executable code in the line.
