Hi there,
We all have used this connection a multiple times. It could be column anchored to the CIP rods or small poles on the drilled concrete piers. But what is the correct provision in the Building Code to inspect the anchor rod to baseplate connection? Who makes sure the nuts are tightened and are installed correctly? These are typically F1554 rods and does not fall under “high-strength bolts” per AISC 360-05. Any thoughts would be greatly appreciated.
Thanks!
"There is no TENSION, it's always a COMPRESSION," said a wise man
Thanks!
