Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Thank you for your kindness in replying.Where to start indeed.
Retrofit?
Access size into tank?
Ask a vendor or do some research.
Thank you, I will take your answer into consideration.For aluminum floating roofs, I would assume the manufacturers would have installation procedures.
For steel, maybe not.
What to consider: Drawings/details, intended sequence of work for assembly, hoisting, checking tolerances, float testing, etc.
I wanted to ask about both types of IFR.The installation processs is very different between aluminum full- and non- contact IFRs.
Are you interested in which part gets installed first, or more general question of should you buy a full- or non- contact IR?
