AntonioPerez
Industrial
I'm working on a project of an existing facility. There is a main switchboard with a molded case circuit breaker in the incoming whose breaking capacity is insufficient for the calculated short-circuit current. That incoming circuit will be properly protected in its beginning, by a new circuit breaker. I'm affraid that if a future shortcircuit causes the opening of that underrated breaker, an arc flash could happen. I was proposing to change that existing circuit breaker by a switch disconnector but it seems that there is no space in the switchboard and the changing operation takes more time than acceptable. I'm not sure of the effects of a breaking operation of a breaker with insufficient breaking capacity. We've checked if that circuit breaker let the breaking coil to be removed but it is not possible. What do you think about it?
