Insulflex vs Armaflex
Zul78289
ID
Dear all engineers,
I wonder what is the main difference between insulflex and armaflex insulation? what parameter should we consider to choose the best insulation? btw, this insulation will be applied to air conditioner pipe and drain.
thank you for your explanation.
warm regards
Thermal Conductivity
Water Vapor Permeability
Working Temperature Range
Fire and Smoke Behaviour
Physical Structure of the Material
