henry.morris
I am designing the reinforcing of multiple steel joists (30K7, 18K3, 36G etc). For the top chord I have specified a 1/2" rod with a 2-12 3/16" fillet weld B.S. The contractor has requested that we limit the type intermittent weld to being on one side of the rod only.
The weld is chiefly there to stop the rod from buckling however I am now concerned that the weld will be put into bending if it is only on one side of the rod. Is this concern justified?
Henry
Henry
