I am currently looking to develop a spreedsheet that will help do backslope calculations for a segmented retaining wall. I am attempting to work through the Appendix B example in the back of the "Design Manual for Segmental Retaining Wall, 3rd Edition" and cannot seem to verify how they are getting a value.
The equation (NCMA EQ 7-50) from the SRW manual is the calculation for the (α[sub]i[/sub]) internal failure plane. I have ran the calculation almost 10 different times now using the numbers from their results and inputing it into the equation given and still my value is off. Does the equation 7-50 in the SRW Manual have some sort of hidden variable that is not shown? I had a fellow engineer print out a computer program output for this sort of problem and the internal failure plane that it yielded was different from the result I got from the equation as well.
I am just at a loss here because I cannot move forward until I can get a value I feel confident in and I cannot understand why this value is coming out wrong when using the given equation.
Thank you for any and all help.
