Intersection
st4r
HR
example: i'm creating a (part)body by extruding two sketches, and these 2 pads intersect (i can't use limits in that case). is it allowed for them to intersect, to just leave them like that, or in that case i must make one of those extruded elements as a new body, and then use boolean operation->add? or it doesn't matter which way i make it?
Hi st4r,
Your post sort of confused me. The method of each pad in its own partbody and then using the boolean operation of add or assemble which produce the same results is good modeling practice. Especially later when having to modify a complex solid. Additionally, if you want the resulting solid from the 2 profiles, try using the combine function. Select sketch.1 and then sketch.2. This will result in an intersected pad.
Hope this helps.
Chewy3000
Thanks Chewy. Actually i was wondering wich way is "more" correct when creating complex solid. If two pads intersect then they are both (also) defined in that same space (where intersection is), although they make 1 body. On the other way by making each pad as 1 body, and then using boolean operation (intersection, now between 2 bodies, still exist), resulting body is "union" of these 2 bodies.
st4r- will you need to use 1 of the pads in a downstream operation? I like the flexibility of the boolean methodology.
Derek
