marc.rogue
I have been analyzing the effects of shoring specifically in prestress members. Some systems call for crown, an additional push of the member upwards are erection. This is usually accomplished by pushing the piece at the middle of the span with a post shore up to the specified crown.I am wondering can this simply be taken as a point load acting at the bottom of the beam or is there a more robust way to go about analyzing this.
Mind you this has an effect in internal stresses and camber. Additional stress is being provided to the bottom of the beam which further compresses the bottom. Also a stress analysis is done and all allowable stresses are met.
