ChipFuller
Does process piping or instrutmentation tubing or hydraulic tubing fall under IPC? Our inspector is saying our process piping that could go to a reactor or the instrumentation tubing going to a gauge or process vacuum piping or hydraulic tubing should be inspected per IPC. Is this true or is this the correct code?
