Alistair_Heaton
- Nov 4, 2018
- 9,832
Seems to be a colossal problem with mica in building blocks.
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Cassidy Brothers said:“These issues were never envisaged by block manufacturers nor indeed reflected in the industry standards set down by the Government.
“We welcome and embrace the recent introduction of regulations for increased block strength in line with expert recommendations. We further welcome that local architects are now specifying the use of blocks which are 2.6 times stronger than the previous Government standard and that experts are recommending the use of a render type which is appropriate for Donegal weather conditions.
I know the amount of water used during mixing is crucial to a proper cure... does this mean increased water during mixing will alleviate this particular issue?Alistair's article said:The main effect of the presence of mica in concrete mixtures is to increase the water demand due to the hydrophilic nature of the mineral. This reduces what is known as the workability of the fresh concrete mix, which is how easy the mixture can be transported, placed, compacted and finished; and this, in turn, reduces the compressive strength of the finished concrete.
MacGyverS2000 said:I know the amount of water used during mixing is crucial to a proper cure... does this mean increased water during mixing will alleviate this particular issue?
waross said:I would expect that poor concrete strength would have long ago become part of the local collective knowledge of concrete durability.
