PressEquip
I've been asked to help design a wrench like tool that will be used at ambient temperatures and exposed to grease, fastener lubricant, rain/snow and a petro-chemical plant environment.
A material that came up was 17-4, precipitation hardened to H900. The condition H900 has high strength and high hardness as shown in the typical data below.
Typical Mechanical Properties
Condition: H900, UTS=200 ksi, YS= 185 ksi, Elong%= 9, Hardness=45 HRC
Condition: H1025, UTS=170 ksi, YS= 165 ksi, Elong%= 10, Hardness=38 HRC
Should I be concern about using H900 due to potential brittleness of the material? Low impact resistance? The workings may be using it at temperature 0F on rare occasions but the tool is used for precise torquing so it shouldn't be smashed around like a mechanics wrench. I was considering that the condition H1025 may be a better choice since because of improved impact resistance but the hardness really drops and the wrench needs high bearing strength where it engages the fastener.
Is there a better suited commonly available (1" thick plate or flat bar), high strength and mildly corrosion resistant material that I should consider?
Thank you for taking the time to read this and many thanks to those who respond.
A Fan of EngTips, share the knowledge
