Greetings
often im facing with assemblies that they need mirror components. "Position associativity" is a major need for design changes. mirror assembly looks very old and is not associative in positioning. the components loose constraints and become full free DOF.
this leads me to use circular component pattern in some cases or import much more components with excess constraining. im wondering because mirror feature, mirror face and mirror geometry behave differently.
before NX i used to be work with solidworks and did not encountered such problem.
so whats the solution or method for postioning components that can be mirrored and position correctly and update respect to source component position and selected mirror plane?
best regards
Javad
NX 12
best regards
Javad
NX 12
