In the NEC there’s an optional ampacity table (Table B.310.15(B)(2)(3) in the Informative Annex B) when the multi-conductor cables are spaced with a cable size between them in a cable tray. When you are running parallel feeders a long distance for high amp circuits this can be a significant savings.
My question is …. Is 3/C armored multi-conductor cable also included in the definition of 3/C multi-conductor cable for the purposes of that NEC table? I think the idea is to dissipate heat, and it seems to me the armored cable is more like wire in a conduit - so maybe not. Do I need to go to the Code forum?
