KirbyWan
Aerospace
- Apr 18, 2008
- 586
On inlet cowls, we often get in panels that have had blind fasteners removed and replaced over the years so that they begin to sound like maracas. The blind rivet butts are loose so they can rattle around in the honeycomb panels, but they can not escape, they are completely trapped.
When faced with this situation does it make more sense to remove the currently installed blind fastener, creating another rivet butt in the panel so that adhesive/sealant could be added to capture the rivet butts so they can't move around or leave it as is, with the rivet butts loose. The primary concern was with relative movement of the rivet butts causing damage to the honeycomb core. On the other hand, we're adding weight from the additional butts and sealant, and reducing the acoustic properties of the panel.
The question I have been asked is "Is this FOD, since it is trapped and can't be ingested by the engine without some more serious event to release them.
-Kirby
Kirby Wilkerson
Remember, first define the problem, then solve it.
-Kirby
Kirby Wilkerson
