Is it possible to find the location/position from the given thickness value?
sluzzer
IN
Hello everyone!
I have an airfoil blade model. Its thickness varies from top (shroud) to bottom (hub) and from right (Leading edge) to left side (trailing edge).
Is there a way to extract the thickness distribution at a section?
Also, it it possible to find the location/position by taking thickness as input?
At present, I am using Deviation gauge tool. But its too tedious to find the position from the required thickness using this method?
I am using NX9. But Please let me know if there is any good option in higher version too.
Thanks!
