DK44
- Sep 20, 2017
- 196
A Shell of a Shell & Tube Heat Exchanger is constructed of CS or LAS MOC requiring PWHT as per Code. Saddles / Supports constructed of CS structural weldable quality are attached by welding to it.
Shell MOC : CS or LAS
Saddle wrapper pate MOC same as Shell.
Saddle ribs etc MOC : CS structural weldable quality.
1. Is PWHT of such saddles / supports required along with the main vessel. Some times the PWHT temperature for CS saddles may be high due to main Vessel requirement.
2. Can the saddle wrapper plate be welded to Shell and PWHT along with Shell and then CS Ribs etc of saddle / Supports are welded without further PWHT.
3. However,if such above PWHT for Supports / Saddles is not necessary but done, is it detrimental to CS materials of the Saddles / Supports.
