Th.Ro.
- Apr 2, 2019
- 23
Is it actually required to put a "THRU" or "THRU ALL" on a through-hole?
ASME Y14.5 (2009) specifies: "Where it is not clear that a hole goes through, the notation THRU follows a dimension."
Any other cut-out geometry is by default assumed to go all the way through a part body if no depth or end condition is defined. Why should holes be treated differently?
I feel, if no depth is given or end condition defined a hole has to be assumed to go through and adding the "THRU" would over-defining the drawing.
