Andres13_X
- May 11, 2019
- 1
Hello, I am working in a proyect and studying the exergy topic, a doubt came. Hope someone could help me to understand better the concept.
Imagine we have a turbine with the inlet and outlet temperatures and pressures and it is known it is bad isolated and so it releases 200kW of heat, and we want to figure out the maximum outlet work it can produce. To find the maximum work, I would have some ideas:
1) We consider the process is isentropic and so we set s1 = s2, and with the outlet pressure we find the isentropic entahpy. Then we perfome the energy balance to find the maximum work, considering the heat transferred.
2) same than the previous, but we ignore the heat that is comming out.
3) Perfom an exergy analysys to find the reversible work.
I am hesisating which approach to follow since for all of them I got different answers, in the next order: W2>W1>W3. In the thermodynamic book of Cengel, to find the maximum outlet work, they use an exergy balance, taking the exergy destroyed equal to 0 and ignoring the heat transferred. But I don't know why this answer is different than the method 1 or 2 I said. That's why my doubt is if reversible work is the same than isentropic work. Thank you!
