Yuyu28
New member
- Sep 6, 2019
- 15
My apologies if this is not the correct forum to post this.
I have a bushing of 8mm nominal OD that requires an ISO tolerance of k5 (8 +0.007/+0.001) to fit into a bearing; this is a given data. I am designing another clearance hole to house the bushing outside the bearing, and I am doubting between using a custom size tolerance range (for example, 8.02 +/-0.01), or the closest ISO tolerance for holes that can fit the bushing without interference. This would be a G8 tolerance (8 +0.027/+0.005), but I have never seen a G8/k5 hole/shaft combination. For that matter, neither G8 nor k5 seem to be common choices of fit tolerances.
So, what would be the preferred choice of size tolerance for a manufacturer:
a) 8.02 +/-0.01, or
b) 8 G8?
a) 8.02 +/-0.01, or
b) 8 G8?
