SprinklerDesigner2
- Nov 30, 2006
- 1,265
I have a 196,000 sq ft warehouse that has a street frontage of approximately 700'.
Not that it really matters but the warehouse will store exposed Group A plastics and I am looking at an ESFR system using pendent K16.8 heads. Pretty standard.
I am going to need six systems with a fire pump but there is a problem. I can not run a bunch of underground because of the street in front and railroad lines at the back and one side. What I would like to do is single 8" run-in to the pump then install a single 8", or 6" if I can make it work, overhead manifold that will end up being around 550' long. Where I can I would drop down to install a separate "riser" with it's own flow switch and control valve.
We've all seen riser manifolds with two, three, four or even five systems being fed off it but what about "stretching" this manifold out over a 550'?
I don't remember where I saw it but I remember seeing something about a maximum of four systems once but that was a long time ago and I could be mistaken.
As far as the local fire official goes he will go with whatever the standard allows.
As far as the standards go I don't think there's a problem but what have you run into?
