Is there is a proper standard for designing choosing and straight coupling splines?
St0RM33
Automotive
Dec 14, 2015
27
Commonly used in vehicle transmission input shaft and axle shafts for example.
Shown below both internal and external types.
381106-S-1620-competition-clutch-evo-sprung-disc-3_61925dee-e5b8-4290-8544-4dbc6f38761b_mdntw9.jpg
My bible for all things technical: Machinery's Handbook. In my opinion, one of the main quick indicators that a mechanical engineer knows what he's doing and is competent in his field is when he has a well-worn copy on his (or her) desk - an actual written copy. Remember books?
Page 2034 of the 24th edition references ANSI B92.1-1970 as a standard for imperial involute splines, and ANSI B92.2M-1980 (R1989) for metric involute splines. Explanations of spline details continues to page 2062. Tables of sizes, geometries, tolerances, classes, etc.
Thanks for the replies but i am actually looking for specific info on serrated splines only. Seems most are cut using 90 degree V cutter, but i've encountered some really weird ones in the field, 74 degrees or so from what i remember and some uncommon shaft size.
