Isight with abaqus: target doesn't decrease
NEROOO
36
I'm using Isight to fit the experiment curve by changing the material constants, however, the "sum of squared difference" remains the same, and actually I followed step by step from the tutorial.
Need your help! Thanks a lot!
Which tutorial have you followed ? Maybe you made some small mistake in the setup.
@FEA way
Do you have any suggestions?
I use .cae as input and .odb output. Target value and simulation value are both read from the .txt file. The optimization part I use Hooke-Jeeve, to minimize the sum of squared difference...
