ISO 8062
RamCast
MX
I'm currently working with steel castings prototypes establishing tolerances for measuirng the FAI. I'm using the table 2 in the Section 5 (paragraph 5.2, Casting Tolerances) in orer to define all limits. There is anote below that says "As a default conditions for the dimensions, the casting tolerance should be simmetrically disposed with respect to the nominal dimension.......". Should this applies for those dimensions on the drawing formn the center line of the casting? or applies for all dimensions (thickness, overall length, hights, etc.)?? How should w e consider this note?? Do I have to split all tolernaces in the table??
Thanks.
If you don't get an answer here you may want to ask in forum1103 or forum286.
Posting guidelines faq731-376 (probably not aimed specifically at you)
What is Engineering anyway: faq1088-1484
