ISV
sasha1
Aerospace
Feb 5, 2008
54
Godd afternood all
Im having problems with the ISV,get an error message
"Failed to initialize machine tool driver. MTD driver may not be valid.
Ive looked through help menu, Step 4 Mounting the part, and it says you must ensure that
A machine tool driver exists in the proper directory of your NX installation.
The problem is it doesnt as far as I can see tell you where that directory is located.
I would like to check that we have the driver installed could anyone tell me where its kept please?
Im running NX6
Are you using one of the sample machines? They're all in:
C:\Program Files\UGS\NX 6.0\MACH\resource\library\machine\installed_machines
This has been mentioned many times but ISV REALLY needs some serious documentation help. And not from additional paid for training programs. I work for a small shop. We hoped to get Vericut but cost is the factor this year. That said, I can put together a machine much easier than with ISV. I hope more effort is put into ISV to become user friendly.
Bill
We are using models supplied from the machine tool company.
I am aware of location of machine models but dont understand where the MTD is located, basically I need to establish if the MTD is a file located within NX and when knowing its location if Ive got it?
After quickly posting I do see there is more info now about the sample files with NX6 (I just switched to 6). There are "Newer" machine configurations as opposed to "Older" machine configurations (must be a change in NX6's setup). Mentions machine_database.dat as the location of the configuration files.
Still, a very daunting task for many. I really need to get this going as well.
Bill
