Hi there,
I am trying to calculate the J integral around a crack between two concentric orthotropic cylinders.
the crack tip node is 56, but at tyhe end of the analysis in the status window the crack front node is shown as 55415 (which does not exist).
Furthermore the J integral values are zero for all contours.
Not to mention the fact I am unable to get the command
GET, J, CINT, 1,,56,,3
work, as I always get an error message on a mismatch with node 56 (in the command you are supposed to indicate the crack tip node).
Hoping the problem is trivial I attach an input file.
thank you very much
Best Regards
Marco
thank you very much
Best Regards
Marco
